my 98' f-150 is having some troubles
Her is a picture of what your pcv hose may look like. Facing the engine, it will be on the left valvecover, and lead to the back of the throttle body. The hose may not have the thick insulation on it. But check each end to make sure it is connected, and without cracks or hole in it. A leak in the vacuum line will result in a lean code.
link.
This other link is the series of photos that the picture came from. The picture is item #34.
http://sites.google.com/site/fordf150p0171p0174fix/Home/
I hope this is of some help to you. The last link is loaded with images of the 4.2
link.
