97 5.4 tune up
97 5.4 tune up
Thinking about doing a tune up on my truck.
I figured I would go with:
motorsport plugs
motorsport wires
stock cop's should be fine right? (120,xxx on the clock)
just did an oil change
I was going to run a can of sea foam through prior to doing the plugs as well.
Anything else I could do?
motorsport plugs
motorsport wires
When I do a tune up on one of those engines, I replace:
*Plugs
*Ignition coil boots
*air & fuel filters
*MOTORCRAFT PCV valve
Replacing all 8 coils is a high expense, I usually replace them only when
they malfunction..
Good Luck!
FordMasterTech
*Plugs
*air & fuel filters
they malfunction..
Good Luck!
FordMasterTech
