Question about truck width
Old May 12, 2009 | 06:54 PM
delmas's Avatar
Hi guys, this is my first post here. I have a question, can anyone tell me how wide a stock f150 is from outside the tires? The reason I am asking is my sister is giving my son her F150 but there is something wrong with the motor. I have to get it on a trailer and I need to know how wide it is to see if it will fit on my trailer. Thanks in advance for any help and I will need more help from yall when I get it home. Thanks again del
Old May 12, 2009 | 08:48 PM
97_MarkIII's Avatar
should be the same as yours, to be safe just add 6 ins
Old May 12, 2009 | 09:00 PM
F150NJ's Avatar
My 2000 scab is 76" across at the tires, including the sidewall bulge.
Old May 12, 2009 | 10:20 PM
delmas's Avatar
Thanks guys, I will go get it this weekend and get work on it. thanks agin for yalls help del
Old May 12, 2009 | 11:17 PM
scotyg's Avatar
do you know what is wrong with the motor?
Old May 13, 2009 | 12:33 AM
migdaddy's Avatar
hes actually swapping it out for a blown 450 for his 16 yr old son
Old May 13, 2009 | 08:26 AM
delmas's Avatar
No, I don't know what's wrong with motor. I hope there isn't too much wrong with it. My brother-in-law is known for not working on something when it stops working and letting it sit. I will know something more by the weekend. I will put a new battery and gas in it and see if it will turn over and go from there. It has a v6 in it. The body is perfect and it ran good the last time I saw it run. Hope it turns out good. thanks for the advise yall!
Old May 13, 2009 | 12:49 PM
If it's a 97 or early 98 V-6, I'd bet it's hydrolocked.
Old May 13, 2009 | 04:24 PM
delmas's Avatar
How do I find out if it is hydrolocked and if it is, what do I do about it?
Old May 13, 2009 | 07:40 PM
Before you put a battery and gas in it, try to turn it over with a wrench on the front crank pulley bolt. If it won't turn, it's hydrolocked and you replace the engine.
