Stuck in 4 low
Some more details might be helpful. Do you have the manual lever or the electronic system. Are you trying to do it while moving, or stopped. I have the electronic system, and to go in and out of 4-LO you need to be stopped, put the truck into neutral, and move the switch back to the 4-Hi, position. Then put the truck back into drive. You can go back into 2WD anytime after that. Like I said, some more details would be nice, knowing what you have and haven't tried already.
Manual Lever's the same way. U have to be in neutral to get it in/out of 4 low... You can try to do it in drive, but it'll just make a lot of really bad noises. Have you checked the linkage (Manual). If it's electronic, check the voltage at the motor.
