Getting new tires need help
Old Apr 28, 2009 | 04:38 PM
sevenseven's Avatar
Originally Posted by ccbrett
Ive already cranked mine i just did it on the ground and just turned each one the same amount. I imagine taking the weight off would make it easier to turn
Did you measure a specific part on the body on both sides to ensure it was level side to side or does it not matter?
Old Apr 28, 2009 | 06:35 PM
JohnBoy88's Avatar
I've got 285/70/17s on my 2wd and they fit just fine. I do have a leveling kit though. But your 4x4 should fit fine stock.
Old Apr 28, 2009 | 08:59 PM
mccollum_007's Avatar
I've got a set of 305/70/17's on mine with just the torsion bars cranked. They rubbed a little but that was with 9" wide wheels. On stock wheels I would imagine you would have very minimal rubbing if any.
Old Apr 29, 2009 | 10:17 AM
thecause17's Avatar
285's on mine, good fit.
Old Apr 29, 2009 | 02:17 PM
Ford Truckin''s Avatar
305/70/17 Buckshots on factory 17x7.5 wheels, paid $660.00 new and cranked the torsion bars and added AAL. Rub the frame at full turn on front but minimal. Rear cleared fine without the AAL.
Old Apr 29, 2009 | 03:56 PM
TylerFX4's Avatar
ive got 315s on mine with the torsion bars cranked bfg a/t 315/70/17
Old Apr 30, 2009 | 08:44 AM
ccbrett's Avatar
Hey where did you get your tires from Thanks
Old Apr 30, 2009 | 08:46 AM
ccbrett's Avatar
On a level surface you can measure from the grong to the top of the wheel opening if it is level now you should be able to just crank them the same turns and it should still be level.
Old Oct 27, 2014 | 10:32 PM
Elucktruck's Avatar
leveling questions
Hey I have 02 fx4 I'm wanting to crank the torsion bars up on to level out my ride. I was wondering have you had any issues since you did and also how many miles you've put on since then. Thanks
Old Oct 29, 2014 | 03:45 PM
illness95's Avatar
cranked tbars 285 70 17 on stock wheels
