wheel bearing?????
Old Jan 24, 2009 | 11:13 PM
supercrewser13's Avatar
wheel bearing?????
i am getting a hmming sound that gets loud then gets low is not really speed specific but is only noticible at highway speeds although if i am on a slight right or left turn on the highway it goes away. Could this be a wheel bearing? my brake rotors are warped in the front and also rear most likely. would not think that could be related though. on a side note my gas milage has been getting worse lately also.
Old Jan 24, 2009 | 11:16 PM
referee54's Avatar
Probably your bearings---my right front sang nicely this fall until I replaced them...all quiet now. Is it from one side or the other---which wheel?
Tim C.
Old Jan 24, 2009 | 11:29 PM
not that i can tell i will listen closer next time i am in the truck but if i had to say i side i would say the driver side front. just out curiousity how hard was i to replace them or did you have them replaced at a shop also how many miles did you get out of them.
Old Jan 24, 2009 | 11:46 PM
referee54's Avatar
I had mine replaced before Christmas---I do not have the facilities to do it---but I do have a very good mechanic that I trust...I also had him replace a tie-rod end and upper ball joints, as well. I guess I would say that I had over 90k miles when the one side went.
If you have the facilities and the ability/tools to do it yourself, I am sure that people on this forum will give you great instructions as to how to do it.
Tim C.
Old Feb 24, 2009 | 11:33 AM
SkyBound85's Avatar
Don't know if this is still ongoing or resolved, but did you try rotating the tires? I had the same thing happen to me and thought it was the front diff or wheel bearings but I realized I had neglected to rotate my tires. Problem solved for 15 bucks.
Old Feb 28, 2009 | 08:17 AM
hennie's Avatar
Hey if this is still going on check your brake pads. Mine was doing this and my brake pads were sticking. I thought they were a little tight when I replaced them. Then over time the tabs will rust and grow a little. (WV climate)
Old Feb 28, 2009 | 08:40 AM
hennie's Avatar
LOHfootball53's Avatar
i replaced my front bearings not too long ago. it was making a humming/grinding noise. my mileage also dropped a good bit.
Old Mar 1, 2009 | 03:26 PM
dmanzzzranch's Avatar
it is real easy to replace, if you have the right tools, especially for the axle nut, i have done it on 4 or 5 trucks...i got 210,000 miles out of the orginal one, just make sure you check the rotors and brake pads , might be the best time to replace them also, i didn't do it first and they caused the other new one to go out, brake pad came loose..also make sure the axle seats up against the bearing good.
