97 egr fitting
Old Jan 23, 2009 | 08:28 PM
blueoval5.4's Avatar
Exclamation 97 egr fitting
i have a 97 f150 4.6. i'm having trouble getting the fitting loose that is attached to the metal tube that runs to the exhaust manifold. Is their any tricks to getting this loose? I thought about trying to heat it. The truck has 140,000 miles... Thanks
Old Jan 23, 2009 | 08:45 PM
MmmBuckles's Avatar
spray some WD-40 on it and let it sit for a while. it took a bit a strength to get mine off. just gotta keep working at it
Old Jan 24, 2009 | 10:56 AM
PB Blaster will work a lot better than WD-40.
Old Jan 24, 2009 | 01:17 PM
Klitch's Avatar
yes pb will work better, it has better penetration properties as well as lube to my knowledge.
you may have to resort to heating it up with a torch if PB and shock therapy using a soft blow hammer on your wrench. if there is enough room you could hit the nut with a ball peen perhaps?
Old Jan 24, 2009 | 08:27 PM
I ended up having to heat it and persuade it with a vise grip and a ballpeen hammer.. Thanks...
Old Jan 25, 2009 | 03:14 AM
Klitch's Avatar
glad you got it without cutting it lol.
