Cruise Control recall question.
Old Jan 5, 2009 | 07:10 PM
str8t six's Avatar
Exclamation Cruise Control recall question.
ive heard that ford made a new switch for the cruise control. does anyone have the part number. i would rather have a new switch then have my truck almost catch fire because of the fusable link that they give you.
Old Jan 5, 2009 | 07:18 PM
bigdad8214's Avatar
I only had one recall on my truck. Same as yours, Ford did it for free and only took about 15min.
Old Jan 5, 2009 | 09:59 PM
novsun88's Avatar
fusible link will solve the problem of the recall... No need for a different switch. Like bigdad8214 said it takes 15 minutes and its free.
Old Jan 7, 2009 | 08:13 PM
ncranchero's Avatar
If you haven't had the recall done unplug the switch immediately. Listen to this statement: When it's taken in for the recall IF the switch is wet with brake fluid you will get the new switch as well as the harness..........understand "IF the switch is wet with brake fluid"?
Old Jan 7, 2009 | 08:20 PM
squeaky3's Avatar
yes the recall is just for the harness to be added in with a fuse it in so if the switch shorts out it will blow the fuse instead of start a fire
the only time that a switch is put on is if the old one on the truck is already leaking fluid into the switch
i have done hundreds of this recall where i work and i have had to replace very few actual switches
Old Jan 7, 2009 | 08:28 PM
str8t six's Avatar
so should i pour some brake fluid on the switch so i can get a new one?
my cruise control has been disconnected since i got the truck.
Squeaky, is the switch you replace a updated design? or is the same switch?
Old Jan 7, 2009 | 08:30 PM
ncranchero's Avatar
I did not say that............ It is an updated switch.
Old Jan 7, 2009 | 09:03 PM
str8t six's Avatar
so do they hook up the fuseable link AND put in a new switch? or do they just put in the new switch if its "leaking"?
Old Jan 7, 2009 | 10:11 PM
1clean42's Avatar
i'm going to the dealership tmrw to make sure my truck has been taken in for the recall...i've only owned it a year, so i have no idea if it's been taken in or not...a truck blew up just yesterday morning and made the local news...was parked next to his house and caught part of his house on fire
Old Jan 7, 2009 | 11:53 PM
squeaky3's Avatar
yes the switch is a new part but i have put very few of them on the f150s but if you get a switch you will get a new little harness thing because the connectors are different but the new switch is designed so that it should not leak so the new harness doesnt not include a fuse or anything like that
1clean42 if you look under your hood at your brake master cyl like the pic a few posts up shows and if there is a wiring harness that is zip tied in there with a lil black box on it that holds a fuse then your recall should be done
if its not then take it to a dealership and have them run an OASIS report to see if the recall is still open on your truck
Old Jan 8, 2009 | 12:24 AM
str8t six's Avatar
ok, i guess ill just get the harness. im not so sure i trust the new switch. since what happened to the old switch that wasnt supposed to leak.
Old Jan 8, 2009 | 01:49 AM
notw77's Avatar
What recall and when did it come out and who does it apply too?
Old Jan 8, 2009 | 02:01 AM
str8t six's Avatar
its about the cruise control brake switch. came out about 3 years ago.
concerns about all Ford trucks and SUV's from 1990 to 2004
Old Jan 8, 2009 | 09:51 AM
gbwinger's Avatar
Just run your VIN number to check it.
That way you don't have to drive anywhere.
http://www.genuineservice.com/genuin...ault?page=Home
Go to the recalls page. type in your VIN and it'll tell you if there are ANY outstanding recalls on your truck.
Old Jan 12, 2009 | 10:14 PM
itsdaman69's Avatar
heres a question for ya'll. i got the recall "fusable link" and january 2008 the cruise quit working/engaging when i set the cruise the cruise light on the dash just blinks on and off when i hit set
