Rear suspension clunk
Old Nov 25, 2008 | 02:06 PM
thecause17's Avatar
I've been noticing an occasional clunk on my '01 coming from the rear. I first noticed it a couple weeks ago when I was on a dirt road and went up over an uneven spot. When the suspension flexed there was a clunk in the rear suspension. I've also noticed it a few times since in regular driving conditions that also caused some suspension flex. Any ideas? Truck has about 99k miles on it. All my searches on here have led to rear end and driveshaft info.
Old Nov 25, 2008 | 02:26 PM
F150Bryan's Avatar
Good Luck on this one. My 97 does the exact same thing. The mechanics can't seem to figure it out either. Sounds just like something shifting in the rear suspension. Its not the u-joint either cause I replaced those. Definitely comes from the rear though!
Old Nov 26, 2008 | 10:39 AM
BLUE20004X4's Avatar
I can't figure mine out neither, weather affects it likely, like expansion of rubber and that kinda thing. I've looked it over well, and rule it "one of those things".
Old Nov 26, 2008 | 09:19 PM
KDracing's Avatar
my 2000 does this too, at first i thought it was all the junk in my tool box banging around but then relaized it's something else in the rear, looked into it further and basically got no where 20,000 miles later truck still hasn't skipped a beat. can't be too serious what ever it is. just turn up the radio
Old Nov 28, 2008 | 10:33 PM
cH1rO420's Avatar
I get it too, used to it now... Probably things just flexxing.. just left it as is.. until someone finds a solution .
Old Nov 30, 2008 | 08:29 PM
02SCSB5.4L4x4's Avatar
Add me to the list, my '02 does it when I turn onto an uphill grade (just about any driveway around here).
Old Dec 4, 2008 | 12:18 PM
novsun88's Avatar
98- mine just started. I was worried but I can't find the noise either. Like others have said it can be heard mainly when going over uneven spots.
Old Dec 4, 2008 | 08:08 PM
cotedog03's Avatar
add me to the list. sounds almost like ball joints popping, but its definately not. and its definately in the rear. just like the other cases though, only happens when the truck starts to flex.
Old Dec 5, 2008 | 01:22 AM
minimonster17's Avatar
add my 03 to the list... i have it too.
Old Dec 15, 2008 | 09:54 AM
97 RedSuperCab's Avatar
My 97 does it and, I too, thought it was the crap in my toolbox sliding around. Since I am a NewB I am glad to hear its nothing serious.....
Old Dec 16, 2008 | 06:04 AM
chrism9232's Avatar
add my 2001 to the list. i thought it maybe the torsion bars
Old Dec 16, 2008 | 07:01 PM
4x4wolf's Avatar
Mine does it too but i think its the leaf springs cause mine doesn't have the clip to keep it together and it looks like its sliding apart and only does it when it flexs
Old Dec 17, 2008 | 04:17 AM
shawnjerdon's Avatar
well, ive seen all heritage years except a 99... strike it off the list, ive got 115k miles on it and noise is in the drivers rear, i have been able to narrow that much down. look closely to the shackles and hangers, i love my fords, but they could have been better built... also look into the leaf spring bushings, noticed that mine was cracked
Old Dec 23, 2008 | 04:52 AM
cH1rO420's Avatar
Ill check that out as soon as i find out what are leaf spring bushings.. lol.. Did you get them checked?? Also did the clunking noise stop?
Old Jan 14, 2009 | 11:33 PM
2000Expedition's Avatar
Rear Disc Brakes? Does it sound like a loose lug nut inside a hubcap? If so check the emergency brake inside the disc
