Programing F150 keys
Old Nov 18, 2008 | 01:48 PM
dcsbass's Avatar
Red face Programing F150 keys
I have a 2001 F150 Ext. cab. I'm adding a remote start. I need to program a third key. I have two and the spare. I know I saw it on here, just don't remember where. I just need info on how to program third key or directions to site...
Thank You
DCS
Old Nov 18, 2008 | 02:28 PM
thecause17's Avatar
This is in the owner's manual. You will need the first two keys you have, and the third key, already cut.
1. Insert the first previously coded key into the ignition and turn the ignition from OFF(3) to ON(4) for at least one second.
2. Turn ignition to OFF(3) then LOCK(2) and remove the first coded key from the ignition.
3. Within five seconds of removing the first coded key, insert the second previously coded key into the ignition and turn the ignition from OFF to ON for at least one second but no more than five seconds.
4. Turn the ignition to OFF then LOCK and remove the second coded key from the ignition.
5. Within 10 seconds of removing the second coded key, insert the new, unprogrammed key into the ignition and turn the ignition from OFF to ON for at least one second. This step will program your new key to a coded key.
If successful, the new key will start the vehicle and the theft indicator light will illuminuate for three seconds and then go out.
