98 f150 keyless entry
Old Nov 14, 2008 | 11:49 PM
oddball32's Avatar
i just bought a 98 f150 and it only has 1 key and no remote. how can i tell if it has keyless entry or not so i will know if i should buy a remote or not..
Old Nov 15, 2008 | 03:33 AM
EBXGSXR's Avatar
maybe pop off the door panel to see if there is a module in there? is it a PATS key? or regular?
Old Nov 15, 2008 | 01:02 PM
Gotts2BMe's Avatar
Jump in turn the forward back, forward back 8 (I think) times fast but without starting it you should see your lock go up and down if you have it. It is possible to have keyless entry without powerlocks. If you do have keyless entry (if the clicks down up quick) then buy the fob off ebay for $20 and repeat the first steps by moving the key back and forth and when the lock clicks press any buttons on the remote and turn the key in the off position, you can add something like 4 remotes
Old Nov 15, 2008 | 04:31 PM
Raptor05121's Avatar
how is it possible to have keyless entry without power locks?
Old Nov 15, 2008 | 08:28 PM
EBXGSXR's Avatar
if you do have it, the programming procedure is in your owner's manual. i bought 2 key fobs off ebay & redid all 3 of mine. super easy. i think i did all 3 in like 1 minute....literally.
Old Nov 16, 2008 | 08:47 PM
Gotts2BMe's Avatar
My 98 escort zx2 had keyless entry on the drivers side only but not the passenger side. Only cost me about $20 to the fob and I had keyless entry. Ford puts all kinds of things into these vehicles without telling anyoe. Also in the same escort I added a keyless power trunk just by adding the button. I also added OEM cruise to it for less than $100 and about a half hour of installation. Ford wires most of vehicles with pretty much everything just because its easier. If you don't have cruise and want to know if you can add oem cruise easily and cheaply. take off your air bag on the steering wheel and see if there is a plug not connected to anything, thats the wiring for the oem cruise.
Old Nov 16, 2008 | 09:10 PM
0.0 can you tell me how to remove the air back cover without setting it off? ive wanted OEM cruise for so long. also want keyless entry too. any info would be appreciated here.
Old Nov 16, 2008 | 09:23 PM
Gotts2BMe's Avatar
To see if you have oem cruise, first DICONNECT YOUR BATTERY. then remove your air bag, It probably has screws in the back, then slide it out of the wy and look for a connector that isn't plugged into anything. If you want take off the air bag and take a couple pictures of the steering wheel, and I will be able to tell you.
To tell if you have keyless entry follow the first 2 steps in the following link, if the lock clicks up and down you have keyless entry, then just buy the remote.
http://www.fordf150.net/howto/reprogramremotes.php
Old Nov 16, 2008 | 09:41 PM
okay, well i dont have power locks. there is a simple metal bar from my lock tab to my handle. nothing else it touching it, so the handle (or key) is the only way to lock/unlock my doors. so knowing that, it is impossible to have keyless entry without power locks. also, i just tried this and it confirms my theory. ill just have to buy an aftermarket power lock kit later. thanks
Old Nov 21, 2008 | 09:56 PM
oddball32's Avatar
thanks fellas i'll check it out....
Old Nov 21, 2008 | 10:00 PM
oddball32's Avatar
my truck has cruise but its not working, neither is my horn. im getting power to the relays and to the harness that goes to the steering wheel but cant get them to work. what could i do to straighten this out..
Old Nov 22, 2008 | 12:25 PM
Gotts2BMe's Avatar
fuse
Old Nov 29, 2008 | 06:56 PM
oddball32's Avatar
cruise control
i have checked the fuses and relays,and then even changed them to double check myself incase they were faulty, still not working, any other ideas????
Old Nov 30, 2008 | 05:32 PM
kingcrete's Avatar
thats weird, if you have checked fuses and relays and everything is working i would try resetting the ecu just disconnect the positive battery cable for roughly 5 mins.
Old Dec 27, 2008 | 11:22 PM
Vikeyboy's Avatar
I bought one of the keyless entry remotes for my 98 F-150. The problem I am having is trying to get the truck into programming mode. I turn the igintion key the 8 times as mentioned above, and as sent to me for programming instructions. I get no response with locks activating. I tried 5 times since this is mentioned for other trucks around 98. Is there any other method to get to the programming mode for the keyless entry?
