oil change from hell.
Old Sep 6, 2008 | 07:02 PM
4x497F150's Avatar
So is mine.^
Old Sep 6, 2008 | 07:28 PM
HappeetxnR.N.'s Avatar
How did you relocate the oil filter?
Craig
Old Sep 6, 2008 | 10:55 PM
You can get these adapters with hoses, and relocate them to anyplace you want. I plan on doing that to mine in the near future.
Old Sep 7, 2008 | 02:34 AM
This is somthing I definitely want to do.
Craig
Old Sep 7, 2008 | 03:45 AM
Klitch's Avatar
http://www.irwin.com/irwin/consumer/...rwinProd100322
it dont care how tight that filter is.
Old Sep 7, 2008 | 09:32 PM
Is there a vendor y'all recommend to get this relocating kit from?
Craig
Old Sep 7, 2008 | 09:54 PM
4x497F150's Avatar
Craig
It came that way.
Old Sep 8, 2008 | 12:57 AM
macisha's Avatar
used to work at an oil change shop and man, have i had some bad experiences.. fords always finds a way to put the filters in the best spots... not
luckily my f150 has the relocation and its in the bumper
Old Sep 8, 2008 | 12:50 PM
JGMM_BC's Avatar
Mine came that way from the factory. I think that all 97 4X4s came that way. Don't know about newer models. I'm sure there is a kit...
Old Sep 8, 2008 | 03:23 PM
i put mine up on ramps, so theres no way for me to get the linkage out of the way. i put a piece of cardboard behind the filter before i unscrew it so it dosent leak oil all over the crossmember
My crossmember has a metal tray in it that catches all the drips, and relocates them to one point. the earlier trucks might not have them tho
Old Sep 8, 2008 | 04:34 PM
ademartin1's Avatar
i changed my oil once on my truck then decided it worth the extra 15 bux to have someone do it and not deal with the mess
Old Sep 8, 2008 | 07:21 PM
TxAg'12's Avatar
Same on my 2000. Makes it much easier since you can just let it drain into some sort of container.
Old Sep 9, 2008 | 12:26 PM
Sundevil2188's Avatar
Changed the oil on my truck once, will pay to get it done from now on. Such a major PITA.
Old Sep 9, 2008 | 01:09 PM
I'm capable of changing my own oil, it's not difficult on mine, but I'd rather spend a bit extra to have it done. 15 minutes and I'm in and out, no crawling under it and getting dirty, no disposal to deal with. The place I use (Mobil 1 Lube Express) is competent and they are good people.
Old Sep 9, 2008 | 02:48 PM
what type of oil do you guys all run? Any advantage in regular vs. synthetic in a 180,000 mile truck?
