3 valve head swap
Old Aug 24, 2008 | 07:26 PM
nemesis500548's Avatar
3 valve head swap
I wonder if, since I hear the change to up the power from '03 to '04 was to switch from 2 valve to 3 valve heads, they can be swapped out?
Old Aug 26, 2008 | 12:21 PM
Veteran: Army
the swap is fairly straight forward, however the throttle body will have to be your 2 valve one and you'll have to work the cams gears so they are not adjustable and you'll have to run the 2 valve computer.
you'll also need the exhaust manifolds and front engine cover at a bare minimum.
check on a couple of the other threads asking this same exact question I posted a link to a saleen mustang getting the swap
Old Aug 26, 2008 | 05:54 PM
Raptor05121's Avatar
tj, im lovin that siggy! i have a V6, and i was thinking the same thing. im not going to do it, but it would be cool to have a 3 or 4-valve V6
