hi im new here and i have a 97 f150 black stepside single cab 2wd. i want to put the 20" harley davidson rims on it and wondering if the lug pattern will fit?? thanks
any place that sells rims will be able to tell u wat will fit and what wont. they will usually give u a list of rims in the size your looking for and you can just search through that.. even if you dont buy it from them.
Yes, both use the 5x135 mm lug pattern. However, you will need lugnuts for your year model truck as the 99-03 F-150's use a 14mm stud instead of the 12mm studs on your 97.
That assumes you are talking about a pre-2004 Harley Davidson addition. If you mean off an 06, no they will not work. 04 and up F-150s are a 6 lug pattern.
