Coolant flush question. 2006 5.4
I better read again. I put about that same amount in; about 2 gallons.
Yes, I flushed entire engine with a hose in the reservoir and ran it about 10 minutes. I have a T pipe ahead of the thermostat that unscrews too. Let it all run at 2000 rpm for a bit too.
Thanks, both of you, for confirming. I questioned the 5 gallons the entire time!
Right. Half of that is in the block and won't drain unless you find and pull the block drain plugs.
If you thoroughly flushed with water and drained what you could, 10 quarts of 100% full strength coolant is the right amount to add anyway. If you used 50/50 premix, you are not even close to being adequately protected.
This is why - just as in the case with transmissions - the best way to do this is take it to a shop that has the appropriate machine.
I was thinking the same thing as you when I did mine a few weeks ago. I just tested mine and it looks to be between 0 and -5 degrees Fahrenheit for the freezing point. My tool says -34 degrees Fahrenheit is about 50/50 mix. I used premix 50/50 so I'm going to take GLC's advice and use 100% concentrate once drained.
If you are going to use 100%, flush it till nothing but clear water comes out, then drain all you can.
There are people here who claim that only distilled water should be used. That's going to be difficult without using a machine unless your water is from a filtered source.
You need it protected down to -34, not only for freeze protection, but also for a proper strength to protect against corrosion.
The way I do it is I drain the raidiator then I drain the block. Then I use the preston flush chemical fill it with hose water and run it several minutes. Then I drain the radiator and the block. Then I fill it with distilled water and run it several minute. Then I drain the radiator and the block. Then I use the unmixed prestone anti freeze and distilled water in equal as I can get it amounts. From now on I'm doing it every year to keep corrosion to a minimum. Had to replace the heater core this year and I never want to do that again.
