04 f150 rough idle
04 f150 rough idle
Hello guys, I have been having a major issue with my 04 f150... I had the cam phasers replaced about three weeks ago and everything was fine then all of a sudden my truck starts idling very rough and knocking then will occasionally stall. The CEL came on and I scanned it and it showed cam positioning sensor over retarded bank 2 so I replaced the VCT solenoid on bank 2 and everything seemed fine, then once again it started idling rough and sounds like a diesel. I can shut it off and crank it right back and it will run fine for about 5 mins then do it again. It only happens at operating temperature if that helps..... Where do I begin? Thanks in advance for your help!!
I had my phasers and solenoids changed a month ago...about 1,300 miles...
My truck is running real rough also...It ran good til last monday...the dealer hooked it up and said that I have low compression in cylinders 6,7 &8...need new engine...I'm at 176k miles...It's not throwing any codes...for giggles, I disconnected the VCT solenoids and drove it...It seems to run a little better with them disconnected... have re-connected them...My truck is showing lean, and rich conditions on the fuel trims...
I have not had an actual compression test done yet...still driving it...I'm having a hard time swallowing the idea of putting an engine in it...plus, I'm broke!
I hope you find an inexpensive resolution!
I changed the oil to a little heavier weight and it cleared it up instantly for a couple of days. On my way home this evening it acted up once again so I just buried the throttle and it cleared it up once again and ran fine all the way home. Could this be a fuel issue. If not, what the heck is going on???
