My 89 f150 is slow
#91
It was easy to make those cars perform way better then they came stock. Adding lower rear end gears plus an overdrive transmission after cleaning off the smog crap and you have a 17 mpg car that also moves pretty good. The Cleveland came out at a bad time. If it had come around 5 years sooner it would have made a better name for itself. Then Ford gave up on it before technology improved To let it pass emissions and be a performance engine.. Hit the market in 1970. Just as the emissions rules were set to go into effect.
#92
Yeah, it was actually a big block engine. Nascar allowed it to be the base for race engines until Bill Elliot's team in the mid 80's had so much more hp than everybody else they disallowed the engine after 86 I believe. Had to go with the smaller block engine based on the 351W. That was the engine used to set the all-time high of 212mph at Talledega in 86. Then the restrictor plates came.
#93
I am going to ask since I don't think it has been brought up....but redneck, what is your goal with this truck? Are you wanting a daily driver that can get up and go a bit more, or a speed demon, or do you want it to pull? That will make it easier for us to suggest what to do.
#94
#95
#96
You have a huge weight disadvantage. My 96 trans am with 285hp and 325 lb-ft I clocked 0-60 in 5.8 seconds. My regular cab shortbed 4x4 ram with 395hp and 407 lb-ft is about 5.9 to 6.1 I would guess (now at high elevation so I don't know for sure). Both had about the same shift points for 1st-2nd and 2nd-3rd gear and my trans am was quicker even with 110hp and 82 lb-ft less. You are going to have to add a bit to beat up on mustangs.
#97
500 hp in a daily driver truck? If you build up an engine for a truck, you should build it for torque, not horsepower. You will also need a different transmission, which also needs to be built. The only auto trans that will bolt to a 351C that's not electronic and can handle that kind of power is a C6, which is a 3 speed with no overdrive. Getting 500 hp out of a 351c needs a lot more than "hardly doin much".
#99
Yes the 351c heads flow high amounts and have big valves. Problem is that they are 70's technology. Velocity not so good. Port size and shape. Not so good. A modern set of aftermarket Windsor heads will own them. A windsor can and will make more usable torque and was a motor actually offered in the 89 truck. Even the Windsor is showing age and people living in the past will be reminded real quick how much faster, more efficient, more reliable the new stuff is.
#100
#101
http://www.hotrod.com/engine-masters/page-2/
#102
head comparison, losts of info
http://users.erols.com/srweiss/tablehdc.htm
before the aftermarket head selection exploded there was a case for running the cleveland heads. now there are plenty of windsor heads that flow just as good, are new and have better numbersin the lower range.
i love the engine masters competition but remember it is a competition with a specific set of rules and basically an unlimited budgets, engines are designed for a dyno competition and in a competition where jon kasse comes in 5th place, you better best these guys are good and $$$$$. thinned bearings, expensive coatings, exotic 1 off parts. kind of like saying you should get a 426 hemi because jon force is making 8000 horse power with one. not a comparison for the common man.
the 302 and 351 windsor were offered in the 89 truck. plenty of factory parts for installation and over the counter aftemarket parts like headers and exhaust.
last unless you go after market, any 351 cleveland head and engine you find will be 40 years old.
just do an ls swap the packaging, aftermarket and power is hard to beat.
#103
Anyways enough about the 350...back to the threads main focus. Basically you will have to upgrade the engine, swap it for a bigger engine or sell it and buy a newer vehicle than 89. Also don't look at the hp and torque numbers so close either. The 302 had more power than the 300 I6 but the I6 was usually preferred for pulling. The numbers given are the peaks. Every vehicle has a different horsepower and torque curve. You could have something with 275 lb-ft have more torque through low range than one with 300lb-ft. For instance the 300 I6 would probably pull way easier than my 4.2L would even tho they were close at the peak
I have a friend who has pulled with plenty of 300s and 302s. He prefers the 302 for pulling. I can understand why, too, since the latest 300s peaked at 2000 RPMs and had less peak torque than the 302. So, where that myth that the 300 is such a great tow monster comes from is beyond me. That's understandable, since they don't rev well and they lose breath very quickly, which sorta' defeats the purpose.
Also, the 4.2L has about 220 lbs/ft just off idle, so for lacking a healthy portion of one full liter of displacement, it manages just fine and will do so if you need more pedal (you know, going uphill) much longer than a 300 would. Bless that variable intake manifold creature.
#104
#105
A couple if things here...
