97 F250 5.4 Cyl#6 Misfire
I have a 97 F250 with the 5.4L V8. Started getting a P0306 code. Changed plug, swapped COP with #5, pulled injectors and swapped #5 and #6. Still polling the same code for a #6 misfire. Compression? Rings? Valve? or am I going down the wrong path and should be checking O2 sensor or EGR, or MAF? Any suggestions? Seems to run fine at 50 but get some bucking at 35-45. Not my primary vehicle so it has not been a real priority but starting to put some time in to get this solved.
