Any Ford Techs. No Injector pulse
Good morning !
I am a new member and think you may have the knowledge I am looking for.
I have a 2005 4.6 engine,trans, pcm, wiring harness. but no insturments. I want to intall in 1992 f150. Can the pats be bypassed? can it be removed with reflash? Do I need after market pcm? any help would be greatly appreciated THANK YOU IN ADVANCE
Steve
Steve
on
Your 05 has the CAN protocol and uses an electric throttle body. Unless you refit it to run like an 04 heritage or older you will need the body harness and instrument cluster for your engine to work. Find an older PCM like was suggested and run it that way. 1999 was the first year for PATS. Unfortunately your engine will have COP ignition and the 97-9 4.6 has coil pack ignition. So the options are:
Purchase the required components to make the 05 work with its PCM. Get out your cheque book....
Purchase a 00 to 04 heritage PCM and harnesses and have a tuner disable the PATS. Don't forget the throttle body needs to be replaced.
Purchase a 97-8 Coil pack set up including the wire harnesses. Don't forget the throttle body needs to be replaced.
Regards
Jean Marc Chartier
PS using your old instrument cluster will present some unique wiring challenges.
Regards
Jean Marc Chartier
