What is a 4.6 Windsor???
Old 01-05-2008, 06:54 PM
Tumba's Avatar
like i said the jap were kicken us good on the quality department
we also didn't have the rev limilters we have now
Old 01-28-2008, 04:27 PM
Novakman's Avatar
Ive been reading up on the windsor and romeo engines and found that in 1999 ford changed the cylinder head design on the mustang to allow for more air intake. Did that carry over to F150's as well? And if they did can I use a 1999+ windsor 4.6l cylinder head on my 1997 4.6l windsor? I have not found anything that says that i cannot do this.
Old 01-29-2008, 09:19 AM
JMC's Avatar
JMC
JMC is offline
In 1999 Ford released a new Power improved head, Pi head. It was first used on the 1999 5.4 F-150 and in 2001 it was used on the 4.6 f-150. Using the Pi head requires a Pi intake or an adapter.
JMC
Old 01-29-2008, 09:28 AM
Dan K's Avatar
Cool
good info to have, beeen meaning to look this up myself, just never got around to it. Thanks guys!!
-dan
Old 01-29-2008, 09:29 AM
01Roush's Avatar
There are adapters for PI intakes on non-PI heads, but I've never seen one for the reverse, so you need (and would want anyway, much better) a PI intake if you use the heads. The main problem with the swap is that the PI heads have much smaller chambers than non-PI and a direct swap raises compression on a 4.6 from 9:1 to something like 10.8:1, can't remember the exact number but way too high for a street motor.
Old 01-29-2008, 01:25 PM
Novakman's Avatar
So with a lower compression piston change and all the right adapters and intakes the PI heads should work on mine then
Old 01-29-2008, 02:39 PM
01Roush's Avatar
If you run PI heads, run a PI intake. The non-PI would kill most of the potential gains. If your shortblock is healthy it would be pretty expensive to change pistons just to swap heads, I would rather have the non-PI ported and use a PI intake. If your motor isn't healthy, it would be a helluva lot easier to just pick up a good PI motor from a boneyard and have the swap done in a day....
Old 01-29-2008, 04:47 PM
Novakman's Avatar
I If your shortblock is healthy it would be pretty expensive to change pistons just to swap heads, I would rather have the non-PI ported and use a PI intake.
Thats a real good point, i didn't think about that it would be very expensive to do all that.
Old 01-29-2008, 07:06 PM
twintips_17's Avatar
-dan
Heres a good web site for more info on the differances.
http://www.babcox.com/editorial/ar/eb40228.htm
Quick Reply: What is a 4.6 Windsor???
