knocking/tapping '99 4.2L -COLD WEATHER!!!
why knocking/tapping sound when started?? - COLD WEATHER??
I was hoping someone could describe to me what the knocking/tapping sound is when I start her up. I've read a few other posts reguarding this issue and the sound i hear seems to last longer than most. It does go away after being warmed up completely. Its got 142k and a buddy told me the bearings are just worn...is that correct???? should i be concerned??
thanks
thanks
It could be your rods. Ford, like the others went to a snap rod. The rods are made as one piece, then scored. After being scored, they are snapped into. This leaves a uneven pattern that causes the rods to wear in a egg shaped pattern. So a egg shaped pattern on a round crank starts to make noise. I have seen this a lot on the 4.2s .
thank you very much for the response! is this somthing i should get looked at and is it gonna continue to give me trouble?? a friend suggested using 20w50 the next time i change my oil but i'm not sure....today was a little warmer and the sound wasn't as bad and didn't last quite as long so maybe its just the weather takin affect on a worn vehichle?
