2005 ford f150 no 3rd or 4th
Hey guys any help is greatly appreciated. I rebuilt tranny abd everything works except 3rd 4th. Good pressure on reverse and drive and neutral. No pressure under direct clutch though hence no third or fourth.any ideas? I'm not sure an odd any codes butt i I scanned it abd just got p1000.
Park idle 60
Full 120
Reverse
150
Ft
255
Drive
125
190
Those are the numbers
Jordan
Park idle 60
Full 120
Reverse
150
Ft
255
Drive
125
190
Jordan
reply
Yes I did replace them. The only thing is I wasn't sure I put the seal in the right direction. I put it in with the lip facing downwards like towards the output shaft and not towards the input shaft (if that makes sense). No cuts at all. It literally has 0 psi, but the computer is commanding it to third. Does this give you any ideas?
Thanks!
