t18 problems
It could be a worn shift fork. It usually will pop out of gear if it isn't fully engaged and that could be the fork being worn.
If it is a fork you may be able to do it in the truck. Could be a worn or sticking detent also. Pull the floor cover and see if you can access all the bolts. Make sure it is in neutral when you remove it.
You can drive it but try not to do what makes it pop out. And yes it can cause further damage, just baby it. If the issue is with any of the rotating parts then the trans has to come out and be torn down.
