stuck in 4 wheel low
Old 11-20-2014, 11:41 PM
Wojo886's Avatar
Hello folks. I have an issue. Got a 98 f150 5.4 lariat and had the transfer case replaced at 106000 miles. Well the shop never got the 4 wheel drive working so the left the electronic shift motor unplugged and i drove around in 2 wheel. Just recently a snow storm hit in buffalo. My truck was stuck. So I plugged the motor in and put it in four wheel drive . Got unstuck easy. Put the switch back in 2 wheel unplugged the .motor and bam now the truck is stuck in 4 wheel low except the front wheels arnt turning. I can spin the back wheels in the snow and the truck will only go ten miles an hour. Anyone have any ideas. Thanks.
Old 11-21-2014, 09:36 PM
Iron woman's Avatar
HAD SAME PROBLEM AS YOU BUT NOT ANY MORE !
Just had my 1999 F-150 4x4 in shop today NOV.21/14. spent 8:30 to 1:30 there. they found the problem, the transfer case shift motor was faulty. I watched the mechanic, put another on my truck & 4x4 & light both worked great, we even took for test drive, in the snow.
Suggest you try that. Hope it works - good luck
Ironwoman
Last edited by Iron woman; 11-21-2014 at 09:38 PM. Reason: forgot to tell @ my problem was same as his........
Quick Reply: stuck in 4 wheel low
