2002 F150 Will not go into 4low
Old 04-07-2014, 11:55 PM
maksimizer's Avatar
New here, never owned a big truck before.
Iv had multiple honda track cars and do my own car work.
Although 4x4high/low/2wd etc is new to me.
Anyways, the truck is a lifted 2002, F150, V6 4.2L, 200kms, Automatic, with the manual shifter for 2wd>4wd>N>4wd(low)
I can shift it from 2wd>4wd, but it will not go into N, or 4wd(low) (cant even move the shifter past 4wd)
(car is stopped, and brake is on.)
I searches up this issue on the Search button, seems as most people have this problem with the automatic switch.
Can someone guide me to a link, or what some issues may be? Only thing i found was shifter linkage could be old? needs some lube?
Thank you
Old 04-12-2014, 03:37 PM
mitymerc's Avatar
sounds like the lever mechanism is corroded/seized. I ran into a similar issue on a 2000 F-150 from Canada. with the mechanism removed from the transmission, I soaked it Aero kroil and worked it back and forth. shifts like a dream now.
you might be able to soak it while still bolted on.
Old 04-18-2014, 02:36 PM
JMC's Avatar
JMC
JMC is offline
Penetrating oil to loosen it up. Just get under the truck and spray a liberal coating on the linkage and spring. Move lever through the pattern till it frees up.
EDIT: Are you moving the lever to the left after you shift it into 4Hi. Pattern is: straight back for 4Hi. Then push to left while pulling further back for N and keep pulling back for 4 Lo.
Old 04-18-2014, 02:47 PM
raider's Avatar
I have had customers complain about this and I would always put transmission in N before going to 4 low.
Old 04-18-2014, 03:22 PM
glc is offline
Yes, neutral and foot on brake.
Old 04-18-2014, 04:16 PM
maksimizer's Avatar
sprayed it with some lube, works like a charm!
thanks a lot everyone!
Old 04-18-2014, 05:53 PM
JMC's Avatar
JMC
JMC is offline
Glad its fixed. FYI on the manual shift you need not have the brakes applied. You need only to be travelling slower than 5mph.
Quick Reply: 2002 F150 Will not go into 4low
