Clutch Question
Clutch Question
Clutch Question
I Just picked up a small pickup truck for my daily driver yesterday. It is a 5 speed with 2.2L 4Cyl. Sometimes when I go to crank I have to pump the clutch to the floor and back up to make it start.
In other words:
If i depress the clutch and it doesn't start, I then release it and push it back down and it starts.
I know nothing about clutches as this is the first 5-speed i've owned. Is this a loose wire in the starter or a bad connection? Or something else?
In other words:
Usually there is a switch just behind the clutch pedal. Get down on the floorboard and push the clutch pedal down with your hand. You should be able to see where the pedal arm makes contact with this switch. It should be a pushbutton lookin' thinigie. It may be sticking and just need a shot of lubricant, or maybe there is wire wear or loose connection.
Hope this helps.
Hope this helps.
yep, sounds like the clutch safety switch. it disables the starting circuit unless you have the clutch disengaged. it's probably sticking...give it a good shot of wd-40 inside where the plunger on the switch slides, then push the plunger in and out several times. if that doesn't fix it, i'd just replace the switch, it's probably only a few dollars.
I replaced the switch earlier and it didn't solve the problem. It was only about 30 bucks so i went ahead and replaced it. I'm going to let my buddy who is a mechanic take a look at it.
Any other suggestions on what it could be?
If you've ruled out the switch, then it's time to start tracing wires. I know, easier said than done but a multitester with some good long leads and an assistant can make things a lot easier.
Chances are a wire is chaffed and is grounding until you jiggle the clutch pedal and it shifts a bit. On old manual Ford trucks this was a fairly common problem.
