Want to Tow my 01 f-150 screw 4x4
I was wondering, my trucks ready from the body shop and instead of paying 90 bucks to have a tow truck tow it about 19 miles I was wanting to pull it behind my f-250 using one of those Tow Bars to tow it. I only need to go about 23 miles down the road. If I put in neutral and kept the in two wheel drive do you think that would hear the transmission or engine? Any advice would help
MP
MP
on
The Ford owner's manual says you cannot flat tow a 4x4 with Automatic tranny and electric SOTF T-case. It does say that you can tow a 4x2 in neutral for less than 50 miles as long as you don't exceed 35 mph. The rear wheels will turn the output shaft of the t-case which is connected to the input shaft. The t-case input shaft is connected to the tranny output shaft so it will turn just like a 4x2 would. I fail to see the problem with towing following the 4x2 limitations.
JMC
JMC
