1997 f250 o/d problem
ok..i took it apart..wire was broken, and had been spliced before..i added a small wire, and still no luck..inspecting the wires, i found several bad spots,,i was getting power on one lead to the switch..so.,i replaced the switch...still not able to take the tranny out of o/d..so,, i took a paper clip, made a jumper, removing all the wiring on the switch side of the harness,and it worked,,said all that to ask this,,is there a complete asslemby, shifter with wiring harness i can replace this one with??
