T-18 or T-19 Tranny
Usually the junkyards around here kill you on just about anything, for some reason it's beyond top dollar (which doesn't seem right for a "junk" yard). Anyhow, everyones gotta make their $. The truck is a 2 wheel drive 150 with a 4.9 and that mazda overdrive tranny. Pre-93 you say? So any T-18 or T-19 that I find pre 93 would work? Why not after 93 seeing as the truck is a 95?
Thanks for the info-
J
J
'93+ F-150/Broncos did not get the T-18 from the factory anymore. So with yer extra details you need a 2wd donor truck or a pre '77 F-250 4x4 which used the two wheel drive case also.
The T-18 or 19 itself can com from any truck, but the bell housing needs to come from a 300/302/351W to have the right bolt pattern.
I know the manual listings are not as complete at the automatics currenly, but the tranny sticky has some more info fer ya.
Adrianspeeder
Adrianspeeder
