Clutch Repair Have any affects on Steering
I have a 2003 6 cyc F150. A couple of weeks ago, with 97500 miles, my clutch went out and had to be repaired by replacing all the major parts at a local repair shop. A few days after the repair, now I'm noticing that the steering when turning seems to have more play...just a little different feel when turning with the steering wheel. Question: When a clutch is being repaired or replaced, is the steering fluid removed and replaced? I was wondering if the wrong type of steering fluid was replaced causing the steering on turns to have more play. I can drive the truck around okay, it's just I'm noticing the steering seems alittle different on turns. Is this an easy process to replaced the fluid? Thanks for any information.
