Camber/Caster Kits Question
I just installed a Belltech #25001 front adjusting drop shock on my 06 FX4 Supercab. My 1st attempt to lower it with my OEM spring and insirting a 1/2 (5/16") spacer, dropped it 3 1/2". Now it's way lower than i wanted, and after a full alignment i still have a negative camber. I found out later they gave me a 2WD instructions install sheet, instead of a 4x4 one. So now i am redoing it, and looking for a 1 3/4" to 2" lower than 4x4 stock, which is what i was originally going for. The kit (Belltech #25001) came with 5 spacers, 2 at 5/16" and 3 at 5/8" for adjustments from 3" drop to a 1" lift. So i'm hoping a full spacer and a 1/2 spacer will give me that 1 3/4" drop i'm looking for. Has anyone other than 05RedFX4 installed this kit on a 4x4? And also anyone know about Camber/Caster Kits to correct the negative camber that will be present after the install? I wanna save my tires from premature wearing. I'll post pictures in my photo album. Thanks all in advance. Cheers Al
https://www.f150online.com/forums/me...s-dam-low.html
