lowering shackle question
i installed a set djm shackles, 2 inches and after installing them the truck didnt change height. the bolts are not overtighten and i had them loose dropped the truck off the jack then tighten them drove around and the is still a 2in difference. i have a 97 f150, im puzzled guys any help would be greatful.
they were longer than the stock shackles, about 2 inches, i dont have a towing package and shocks havent been changed on it. i did put a hitch on, i measured from center of the wheel hub bottom of the fender front and back, the rear is exactly still 2 inches, it has me baffled, im attending UTI its a well known auto technical school. what is the angle from bottom mounting hole to the top mounting hole, it sits right now about 1 o'clock
