Rear blocks for lift kits...
I hope someone can explain this for me as I cannot figure it out. I have a 4" rancho kit waiting to be installed. I am looking at possibly adding another inch or two to the kit. I know the front I could add a leveling kit but as for the rear, I was thinking of using a block kit from a 6" kit but all the ones I see only add up to what the rancho kit comes with? For example, the rancho kit requires removing the stock 2" block and put in the 4.5" block. The pro-comp 6" kit requires adding a 2.5" block with the factory 2" block thus only giving the same 4.5" rear lift. So how does the 6" kit actually give 6" and the rancho only 4" if the rears are lifted the same height? Also, If I just add the rancho block to my stock block, where could I get new u-bolts with the proper length?
