Rear crossmember bracket cut for 6" lift????
As everyone probably already knows I have the 6" procomp lift which required me to cut the mount for the rear crossmember in order to drop the front differential. Eventually I may go with the Rize. Does it also require it to be cut or would I have to get the braket welded back on? Just asking for future reference, not doing anythime soon.
i'm not sure if you have to or not....here's the instructions, what a joke, not 1 picture
www.rizeind.com/06technical/03instructions/f150_instructions/04F150 03 Install Instructions 060411.pdf
There's a seperate pdf for all the pictures and diagrams actually
http://rizeind.com/06technical/03instructions/f150_instructions/04F150%2004%20Figures.pdf
This is the diagrams one that shows you do have to cut it.
http://rizeind.com/06technical/03ins...S%20060411.pdf
If it's welded back right shouldn't be any problem.
