anyone have this lift?..
http://www.roughcountry.com/ford_2wd_97-03_f150_3.html if so i want to run 33s on a 16 or 17inch wheel. do you think its possible. i have a 01 screw 5.4
i still can't believe you can only run a 31" with a 3" lift. you can run any size rim you want just need to be close to factory specs to get minimal rubbing. if you can find a tire shop who will mount 33's on the rims you want and test and check for rubbing that would be your best bet, but if you seriously want 33's dont settle just because your settled on this lift. choose tire size, then choose the lift that fits what you want.
