steering stablizer
Old 10-14-2007, 11:56 PM
Wang13256's Avatar
steering stablizer
i recived a steerig stablizer with my pro comp shocks... are these hard to put in if not done perfessionally... anyone have them.. any advice.. thanks.. TIM
Old 10-15-2007, 12:02 AM
fmf300ex's Avatar
Pretty easy install once you figure out where the brackets and bolts are supposed to go. I put the Rough Country one on that came with my lift at 1 in the morning sitting under the truck with a flashlight.
Wasn't too bad of an install for my 84' at least.
Old 10-15-2007, 12:24 PM
wandell's Avatar
It's pretty easy to install, if you do like I did. I didn't want to remove my lower control arm bolt and install the mount, so I just purchased a bolt and mounted it to the existing hole in the frame next to the lower control arm. Here's a pic.
Old 10-15-2007, 02:20 PM
Wang13256's Avatar
thanks alot.. that really helped me out... enjoy.. TIM
Old 10-15-2007, 09:59 PM
Wang13256's Avatar
a few more ? about suspension
wandell i was thinking about getting an add a leaf kit but not sure what it would do for my truck.. i am not lifted and plan to stay that way or just get a 3'' body liift in the future.. and i have pro comp shocks.. what ill it do for me and is it worth it... yes it kind seems like i wanna spend money and was looking into that.. do u have pro comp shocks.. my reason for asking is i have them and my ford mechanics told me they couldnt use the bushings that came with them and i forget why so im running on the facotry bushings.. anything i can do.. or would u kno why they didnt work.. i really appreiate ur help.. ur one well respected member here.. if anyone has any advice please let me kno.. i could use the info.. thanks.. Tim
Old 10-16-2007, 08:42 PM
wandell's Avatar
It doesn't sound like you need an aal. It will raise your rear end slightly and make your rear suspension slightly stiffer. I have Pro Comp ES3000 shocks. I used the Pro Comp bushings and I don't see why your mechanic would not be able to use them.
Quick Reply: steering stablizer
