Water/Methanol Injection Rocks!
I finished installing a Water/Methanol kit from Snow Performance.. It took a while to figure out the best place for everything, but folks comment me on how factory it looks in there.
If you are considering it, do it. This thing makes awesome power. I didn't even compensate for more timing yet (and am told I could go as high as 26 initial, but will keep it limited to 20). I have to say that it is probably the best mod to date. Plus you don't have to worry about bad gas, etc.
I hope to get some time slip's soon to see how much difference it makes. Everybody that's been in my truck was really impressed with the new performance.
The best I can do for now is these 3 links. I can't share directly from Sprint.
Front side showing Water/Methanol bottle on new bracket.
Back side of new bracket, showing variable controller.
Nozzle Location
Hope that these links work OK.
Nozzle Location
I know that the first Lightnings had a problem with the coatings, had nothing to do with water/meth injection. If you search through the posts you can find many rotor coatings in the top of the intercooler. This has nothing to do with Water/Methanol injection. It was a concern of mine also.
There's other L Bro's running and praising Water/Methanol injection, DEF is a smart move,
Of what little I can see in those pic's , it seems like you did
a real nice install,
CONGRATS Please keep us informed
BTW
I'd love to see someone turn a KB built Motor up to 20-22 Degrees and try this system on the 1320
BTW
Thanks Rob,
The bad news is that the pics don't do it justice. The good news is that you can't see how badly I need to clean the engine compartment.
Now I know why people love the Water/Meth or Water/Alcohol injection. I still can't believe how much better it runs. I hope to get to the 1/8th track this Friday.
Water injection like any other mod is hard to have a generic answer for, if it works or not.
If you have a good intercooler and no crappy fuel detonation problems, then water injection will not be of much benefit. It can actually hurt at some point, as water can't be compressed and the dynamic compression ratio can rise. Keep in mind that water injection only keeps the motor from detonating and utilizing the motors potential.
If you are turning the boost up and want to run 'pump fuel', then water injection can help allow this.
A lot of aftermarket s/c or turbo bolt on kits don't even offer an intercooler, as the boost is not high enough to cause any heat problems and substantial power loss.
I believe past posts have covered the heat increase with boost and how the intercooler is bringing temps down to show factual numbers.
I have mine set to turn on at about 6 lbs of boost (autometer, not stock gage). If I run above 6 lbs then the injection starts and the contents of the tank go down. I don't know exactly how many minutes the tank will last at WOT. I hope to get some track time this Friday and see about how long the water/meth lasts.
easterisland has run it for longer than I have. I'd bet he has a good idea of how long it lasts. For me it's not an issue, I only fill it when it gets below 1/4 tank. I'm running 20 degrees timing on 93 octane fuel and I don't have to run race fuel.
I always thought (from reading too many posts from non owners)that it only made power by allowing more boost and timing. With those items exactly the same, on my truck, it made lots of power. I don't know if it is because of cooling, or the methanol, or both, or something else. All I know is that it works great. I bet everybody else that's running one on a lightning (or anything else force inducted) would agree.
