Starmate 4 to Pioneer HU IP BUS question
Is this what I need to connect my starmate 4 to my Pioneer dehp-880prs..
http://www.amazon.com/gp/product/B00...F8&me=&seller=
I looked everywhere for Pioneer to Sirius IP BUS cables and maybe the pics were screwed up but it never seemed to look right. This link looks like what I'd need. I was going to go the route of FM direct connector and did in my truck, but wanted to try this way out too.
Yes, as long as your pioneer is not 10 years old it should work just fine, it will plug into the back of the radio and then the 3.5mm jack will run directly into the Audio output on the dock of the starmate 4. Once it is plugged it should become a source but if it doesn't its just something that needs to be turned on in the settings..
This way is easier to install and easier to use because you dont mess with radio stations like with the FM Direct, but the sound quality should be close to the same, if not a little better with the IP-Bus piece.
