'91 F150 auto tranny question
Old 11-07-2015, 07:55 PM
mick91f150's Avatar
just picked up this truck 2 weeks ago....dont know what trans is in it...302 motor....but when it shifts from 2nd to 3rd the converter locks up immediately.
it drops in RPM from say 2000 to 1200 which then feels like it falls on its face. any ideas guys? i want to put a picture up but cant figure it out yet.
Old 11-07-2015, 08:35 PM
glc is offline
This will help you ID the transmission - it's either an AOD or E4OD.
https://www.f150online.com/forums/ar...tion-page.html
To post a pic, simply click the Image icon at the top of the reply window - it looks like a mountain - and follow the prompts.
Old 11-07-2015, 08:41 PM
mick91f150's Avatar
thx glc
must be a E4OD but I dont have a OD lockout switch...unless its hidden..
where can a find a list of gearing info... I think its 18 or 19. rear gear.
Old 11-07-2015, 08:42 PM
mick91f150's Avatar
Old 11-08-2015, 12:08 AM
glc is offline
If you don't have a lockout switch, you have an AOD (code T) which is not electronically controlled, it uses a TV cable from the throttle linkage. If your quadrant is PRN(D)D1 it's AOD, if it's PRN(D)21 it's E4OD (code E) which is electronically controlled.
Lockout switch for a E4OD is on the lower dash, right side of the steering column if I remember correctly.
19 rear gear is open 3.55, 18 is open 3.08.
If you have AOD, there's a procedure to adjust the TV cable, there are some YouTube clips on it.
Old 11-08-2015, 02:12 PM
mick91f150's Avatar
its code T with a code 19 rear. thx!!! Ill look on YouTube
Quick Reply: '91 F150 auto tranny question
