05-02-2012, 06:28 PM
opinion please...replace heads or go all out 92 5.0
So I have a 1992 F150 5.0 with 185000 miles. Cylinder #8 is 80lbs where the rest are between 170 -180 lbs. Comparing prices and work involved, should I
just replace the heads (gonna do both sides just because it makes sense to me) or should I go for a remanufactured engine?
Thanks in advance
05-02-2012, 09:45 PM
1990 Ford F-250 My Garage
Vehicle: 1997 Ford f-150
pull the heads first and look at the pistons, cylinder walls, ect. if you see any visible damage go re-man, if not just do the heads.
Thanks Shifty219 for the sigpic!
Check out my new build thread! (Building 1990 f-250)
http://www.f150online.com/forums/pre...on-better.html
-Wyatt
Quote:
Originally Posted by jbrew
You can stop your pathetic drawing on my truck. Better hope I don't resort to that, I'm a fricken artist.
05-02-2012, 10:52 PM
1996 Ford F-150
Vehicle: 1996 Ford F150
Do a wet/dry compression test before you do anything else.
If #8 is reads much closer to the same as the other 7 on the wet test, the issue is not the head, it's the rings or block
1996 F-150 XLT, reg. cab 6.5' box, 4.9 I6. E4OD w/ B&M alum sump, auxiliary cooler and external filter, Addco 1" sway-bars F&R, Bilstein shocks, 16 x 8 AR Bajas w/255/70-16s, Line-X spray in liner, hinged tonneau, Reese hitch and electric brake controller, VDO tranny and engine oil temp gages, stainless pushbar, Hella 550 fog and driving lights, Hella backup/work lights, 3.73 Trac-Lok w/ an alum. diff. cover with cap support screws, PFC "Z" brake pads, high flow cat with a 2.5" cat back with a FM 70 muffler.
05-03-2012, 03:26 PM
was trying to avoid that step but it does make more sense to do it that way
gonna do that tomorrow or Saturday when I have more time.
thanks to you both for the replies
05-03-2012, 11:02 PM
1992 Ford F-150
Vehicle: 1992 Ford F150 4X4
First of all, going "all out" on a old lame 5.0 rebuilt is a waste of money and time. What do you want to do with the truck? your 4.6 is due to be rebuilt or tossed anyway.
It you want to go "all out"....stay with the MOD motor and put your money in a stroker motor is you want to buy tires everyother month. You might even be able to find a Cobra motor online and sell the factory junk super charger for a REAL BLOWER, (ATI).
For the price of what your about to spend on a rebuild of a Slow 5.0 you could have a "NEW" 5.0 550+ HP MOD moter...may even get 23 MPG.
05-03-2012, 11:53 PM
 where are you coming from! mine is fine! we are talking about the i do believe 94 with the original 302! i myself plan on 4v heads in the future, but until then my mod motor wont be tossed, it'll be rebuilt!
09-29-2012, 02:24 PM
Well its been a few months and I have been putting cash away for this project. Truck isn't an everyday vehicle so waited until after the summer to get started. It ran fine enough for the occasional Home Depot or Lowes trip along with getting me to the lake for some fishing.
I decided to just go ahead and rebuild the 5.0. Going to pull the engine, tear it down, have the block checked out and than order a rebuild kit. Not sure yet what cam and heads I'm going with but not looking to go crazy.
Will also be rebuilding the transmission while the truck sits. At almost 190,000 miles, IMO, better to just do it now so I don't have to deal with it later.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
