1988 problems. Need help!
I have recently recieve my brothers broncO. It's a 88 automatic wIth overdrive and is a 5.0 liter. It use to run goOd but has set for a few years and now I'm trying to fix it. It fires in all cylinders for like 5 seconds then starts missing. So I changed all the spark plugs, wires, distributor cap, and the button. Basically a tune up. I'm 17 and not really sure of what else To do because it still fires up great and then misses. You can drive it still but its just so rough I dont know what to do. Does anyone have any ideas or have had this hAppen to them.
After it fires up only 3 cylinders work good. 5 of them dont.
If it has sat for a few years, I would suspect the gas in the tank to be all varnished up. Does it smell like turpentine if you take the gas cap off and push that center button and smell in there? If so you may have to take the tank off and flush it out somehow. At any rate I would start by changing the fuel filter. Also make sure you have plenty of fresh gas in there if you don't have to flush the tank.
