Brake Upgrade?
Brake Upgrade?
So I looked through the threads and couldn't find exactly what I was looking for.
Has anyone ever put f350 front brakes on an F150?
I ask because I am putting 265/75R16's on mine and may have the chance to ****** some up...but I dont know if it would work considering they had 6 bolt rims not 5...
Just want to make sure it still stops like it does now, i keep jurking my neck when I touch the peddle!
I ended up putting an F350 master cylinder, booster, and rear cylinders on my F150. My brakes work much, much better now. As far as the front brakes, there's some years of Thunderbirds that have a dual piston caliper (better) but you need to grind the calipers to make them fit, even with 16 inch rims. I opt'd to not do the caliper swap and I'm happy. Everything was a DIRECT swap, and cost very close to the same prices as the original parts.
As stated above, you'll be fine with the stock brake setup with that tire size.
