Help Please high idle
Been trying to track down the reason for a code 172 (lean) for a while now. The other day i removed and cleaned my IAC valve. when i put it back i cleared the memory started up and the idle was real low and unpluging the IAC made no difference. Went and got a new IAC and installed, now idle is 1200-2k. The voltage at the IAC is 10.56 KOEO and 14.5v running. disconecting makes no difference. i checked the TPS 0.89v idle and 4.5 WOT. Ran KOEO 111 Ran KOER 411 412 unable to control engine RPM. but atleast my 172 code is gone... checked for vac leaks
any ideas
any ideas
on
Did you read these?
https://www.f150online.com/forums/se...archid=4164358
Did you buy the cheapest IAC from the zone, or did you get a Wells with a MotorCraft PN from Advance?
