Transmission help
Transmission help
I recently aquired a 1994 F150 reg cab short bed 2WD with a 300 straight 6 engine for $200. The transmission is needing replaced, and I have been looking but cant find much that I can afford. So my question is this, what tranny can I put into this truck (4 speed or 5 speed manual) that will work. I know pretty much any manual out of a 87-96 will work, anything older than that, that the bell housing bolt pattern will be the same? Any help is appreciated.
Well, if you were closer to Virginia, I have two transmissions in my garage that would work. What is in it? If it is a 5 speed and the internals are bad, I've got one of those that needs the shift rail mechanism. Other than that, I have a 87 4 speed that came out of a two wheel drive truck. I would take less than $150 for either. As for your question, it is always easier to replace it with what you already have due to driveshaft and crossmember issues.
