Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Other F-Series Trucks > Pre-1997 Models
Thread Tools Display Modes
Old 08-06-2008, 04:42 PM
Vehicle: 1992 Ford F150 4.9 L
Lightbulb 92 F150 XLT 4.9 300 6 engine electric issue
Just installed an engine and is running good when it starts. When the engine first starts cranking it is zipping along then all of the sudden the cranking slows dramatically and then all of the sudden it cranks faster until it starts. When it starts, It looks like there is a pretty good amp draw on the amp meter but it is still charging. When I turn on the lights, the amp meter is almost pegged on the low side. But here is the weird deal, when I put a load on it like the lights or something, the oil pressure and water temp gauges peg out on the high side. What the heck is going on? I believe the amp meter a little but I don't believe the water temp and oil pressure guages when an electrical load is applied. I don't get a check engine light either. I also had a spare alternator I tried with the same results.
Old 08-06-2008, 10:49 PM
Vehicle: 1995 FORD F150
The Cluster has a bad ground.
More than likely it is the body ground under the hood and the body is not grounded very well.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
