Axle seal
While your in there replace both sides seals and outer bearings.
Doing it yourself it will only cost another $25.
With the year and milage there has to be wear on the bearing also which could cause the new seal to fail prematurely.
If there is gear oil in the drum that means your rear brake linings are contaminated also. Replace those linings so your rear brakes will continue to operate effectively.
