BAD Wing Window
BAD Wing Window
I am looking for the best way to fix a wing window on the driver door of a 1994 f150, it has been pryed so many times that it leaks terribly, First is there some how to rebuild that framing or do you just pick up a good used door, and if you do replace the door can you use one without the wing like on a bronco???
on
Bronco doors are exactly the same as Fseries.
Click the black Bronco in my signature & look thru the Doors album. The frame can be removed, disassembled, & repaired or replaced fairly quickly & easily.
But you MUST use a '92-96 vent window. The big frame (shaped like a "4") can be '87-96, but the rubber, the glass, & it's steel channel must have the flat front to fit past your door panel. '97 Fseries over 8500GVWR use the same door/vent window.
