92 f150 dual gas tank problems
Old Oct 25, 2006 | 03:56 AM
hazle-ford's Avatar
Question 92 f150 dual gas tank problems
i recently purchased a 92 f150 with dual tanks.when i put gas into the front tank it seems to slowly pump into the back tank.the back tank is newer but wont run off it because the previous owner said the line may be kinked when he installed it.i want both tanks to work as they should from the dash switch.both gages work and the back tank is now full from the front tank pumping into the back.maby i could put a valve on the line to stop the flow??? i dunno.
also how are the 300 6cyl engines for durability??
Old Oct 25, 2006 | 01:06 PM
lurch241's Avatar
the 300 is a strong runner i got a 93 with a 5 speed and i love it doesnt kill me on gas and has alot of low end torqe pull trailers all the time with it never had a problum with it wish my truck was 4x4 but i got a deal on it so i cant complain
Old Oct 25, 2006 | 03:31 PM
Remington22's Avatar
i bought one with 50k on it. 4000 miles later and the only problem ive had is a bad alternator. Ive heard this engine is good out to 300k! The only thing is i feel like i really have to step on the gas for it to really GO! not much power or pickup but other than that its a good realibe truck so far
Old Oct 26, 2006 | 09:42 AM
subford's Avatar
You have a bad Fuel Delivery Module (Fuel Pump) in the rear tank.
Old Aug 12, 2007 | 08:38 PM
hockeyfanjeff's Avatar
Exclamation Same issue....URGENT
Just started happening on my 93 today. I noticed that both my tanks were 3/4 full as of last night. did some driving this morning and noticed that the front tank was now 1/2 full and the rear tank was completely full. Is it a bad front fuel pump or the check valves and fuel pressure regulator? How do i go about replacing items for this problem?
Old Aug 12, 2007 | 08:54 PM
krazyballer's Avatar
This is a recall http://www.automallusa.net/1990/ford/f-150/recalls.html
Check it out.
Old Aug 12, 2007 | 10:57 PM
thanks for the recall notes
Old Aug 13, 2007 | 04:04 PM
No problem
Old Aug 13, 2007 | 08:15 PM
Steve83's Avatar
Jeff
You should change the year in that URL to 1993 & read the ones that actually apply to your truck.
Old Aug 13, 2007 | 10:43 PM
My bad http://www.automallusa.net/1992/ford/f-150/recalls.html here is the one your looking for.
Old Aug 13, 2007 | 11:57 PM
Originally Posted by Steve83
Jeff
did that thanks though Its goin to ford tomorrow to get worked on
