91 f150 clunking noise???
I have a 1991 F150 xlt lariat, 4x4 5.0 auto. I haven't had any trouble with it until a month ago. i decided to take a ride and i just started to leave the drive way and i started hearing a light grinding noise that progressively got faster as the truck went faster. I drove it for a while and the noise didn't stop, so i turned around and headed back. As i came to the driveway, i used the brakes to come to a complete stop, one clunk... then another, and it stopped. The noises seem to happen after driving for a while, but at times may start as soon as the truck moves. The brakes have plenty of stoping power, though i don't recall brake work ever being done on the truck since i've owned it, other than a new master cylinder. I've owned it for around 3 years, and have never had this problem.ster. I drove it for a while and the noise didn't stop, so i turned around and headed back. As i came to the driveway, i used the brakes to come to a complete stop, one clunk... then another, and it stopped. The noises seem to happen after driving for a while, but at times may start as soon as the truck moves. The brakes have plenty of stoping power, though i don't recall brake work ever being done on the truck since i've owned it, other than a new master cylinder. I've owned it for around 3 years, and have never had this problem. I haven't got around to looking at the brakes yet, but i checked all the fluid levels for everything, and they were all where they needed to be... Any clues???????
The noises seem to be coming from the front passenger side.
I took off the passenger side front tire, and looked at the brakes. The pads are still there and look fine, and the rotors look good, smooth without any gouges. I haven't checked the other side yet, but the sound was coming from the passenger side. I took it for a short ride, about a mile, and got the engine up to temp, and got to a normal road speed, and used the brakes, and there was no sounds. But the last time i took it for a ride, i went about 10 miles, stopped and came back, and right as i started heading back, a grinding noise started again. So it doesn't hapen very often, and if it does, it usually happens after driving a while. Any other ideas??? We might be taking it in to a local shop with in a week or two, and i'd like to se if i can get a good idea of what it could be before i take it in.
I took the truck out ice fishing this weekend, and it made no noises or anything, i had to shift it into 4wd to get through my yard though because of snow, and it was a little too loud because of bumps to notice any noises, but i don't think there were any. I am waiting for a nice warm day to check the front differential and hubs. When i removed the front tire, i found that the socket wouldn't fit on two of the lug nuts, it turns out that they must have been over torqued by the last place that put on the new tires, because they were expanded and cracked. I managed to get them off with a much bigger socket, but that was a real nice set back. The hubs in front are auto-locking if that matters any.
My 1993 f-150 4X4 sounded the same way. When I pulled off the rear drums a pile of parts fell to the garage floor. I had to replace everything including the drums then all was well again. As for your lug nuts the problem is Ford decided to put chrome caps on bare steel nuts which rust and swell eventually splitting open the covers and making it nessesary to use a larger socket to fit.
yeah, the funny thing about those lug nuts, is that no sockets would fit it somewhat snug. One was just enough to fit about 4mm's on to the lugs, but a size bigger and it was very loose almost stripping the lugs edges off, so it was a no win situation, but i used the big socket, and managed to get them off to check the front brakes, and still get them back on with enough torque. I don't think the noise on my truck could be the rear drums, but it could be anything.
