3 wheel drive?
3 wheel drive?
Got a problem with my 4 wheel drive. The 4 wheel drive wasn’t working for a while until I discovered the wire from the PDB to the shift relays corroded and broke away from the PDB. I fixed the wire and replaced the transfer case shift motor in the process. When I put the truck in 4X4 mode things didn’t sound right so I put the truck on jack stands to check things out. In 4X4 mode, I found drivers side front wheel is just barely turning and it appears the other 3 wheels are turning as they should. The truck is a 1997 F-150Anybody have any thoughts?
